发电机组专业术语中英文对照大全
查看1987 | 回复4 | 2011-9-17 14:27:04 | 显示全部楼层 |阅读模式
A
AC
Alternating Current (AC) is electric current that alternates between a positive maximum value and a negative maximum value at a characteristic frequency, usually 50 or 60 cycles per second (Hertz).
交流
交流是指电流在正负最大值之间以特定的频率变动,通常频率为50或60赫兹。
ANSI
American National Standards Institute.
美国国家标准协会
美国国家标准协会
Acoustic Material
Acoustic material is any material considered in terms of its acoustic properties, especially its properties of absorbing or deadening sound.
声音材料
声音材料,特指有吸音或隔音特性的材料。
Active Power
Active power is the real power (kW) supplied by the generator set to the electrical load. Active power creates a load on the generator set's engine and is limited by the horsepower of the engine. Active power does the work of heating, turning motor shafts, etc.
有功功率
有功功率(kW),是指发电机组实际供应给负载的功率,它由发电机组的发动机提供,受到发动机马力大小的限制。发热和驱动马达转动靠有功功率完成。
Air Circuit Breaker
An air circuit breaker automatically interrupts the current flowing through it when the current exceeds the trip rating of the breaker. Air is the medium of electrical insulation between electrically live parts and grounded (earthed) metal parts.
空气线路断路器
空气线路断路器的功能是当电流大小超过断路器的过流跳脱设定值后自动断开。空气是带电零件和接地金属零件之间的绝缘介质。
Alternator
Alternator is another term for AC generator.
交流发电机
交流发电机
Amortisseur Windings
The amortisseur windings of a synchronous AC generator are the conductors embedded in the pole faces of the rotor. They are connected together at both ends of the poles by end rings or end plates. Their function is to dampen waveform distortion during load changes.
阻尼线圈
同步交流发电机的阻尼线圈是指嵌绕在转子磁极间的导线,他们分别在两极用端环或端板相连接,主要功能是减弱因负载变化而引起的波形畸变。
Ampacity
Ampacity is the safe current-carrying capacity of an electrical conductor in amperes as defined by code.
载流容量
载流容量是以安培数来定义导线安全载流能力。
Ampere
The ampere is a unit of electric current flow. One ampere of current will flow when a potential of one volt is applied across a resistance of one ohm.
安培
安培是电流单位。1伏电压作用于1欧姆的电阻上就会产生1安培的电流。
Annunciator
An annunciator is an accessory device used to give remote indication of the status of an operating component in a system. Annunciators are typically used in applications where the equipment monitored is not located in a portion of the facility that is normally attended. The NFPA has specific requirements for remote annunciators used in some applications, such as hospitals.
指示器
指示器作为一个附属装置常用于远程显示系统的各个组成部分的运行状态。指示器通常使用在监测设备不在设备现场的应用。美国国家防火协会对指示器在某些行业的应用有特殊要求,例如医院等。
Apparent Power
Apparent power is the product of current and voltage, expressed as kVA. It is real power (kW) divided by the power factor (PF).
视在功率
视在功率是电流和电压共同作用的产物,用kVA表示。它等于有功功率(kW)除以功率因数。
Armature
The armature of an AC generator is the assembly of windings and metal core laminations in which the output voltage is induced. It is the stationary part (stator) in a revolving-field generator.
电枢
交流发电机电枢的是金属芯和绕组的总成,产生感应电压。电枢是旋转磁场交流发电机的不动部分(定子)。
Backup Protection
Backup protection consists of protective devices, which are intended to operate only after other protective devices have failed to operate or detect a fault.
后备保护装置
后备保护装置是在其他保护装置动作失败或发生故障时动作的保护装置。
Bandwidth
The amount of data that can be transmitted in a fixed amount of time. For digital devices, it is expressed as bits per second, or bytes per second. For analog devices, it is usually expressed as cycles per second, or Hertz.
带宽
在固定时间内可传输的数据量。在数字化设备中以位/秒或字/秒表示,在模拟(数字)设备中以周/秒或者赫兹表示。
Base Load
Base load is that portion of a building load demand which is constant. It is the "base" of the building demand curve.
基本负荷
基本负荷是指建筑负荷需求量中不变的那一部分,是构成负荷需求曲线的基数。
Baud Rate
The speed of data transmission in serial data communications approximately equal to the number of code elements (bits) per second (BPS). Bits per second are also termed BPS, with the prefix (k) denoting thousands.
波特率
串行数据传输速率,约等于每秒钟传输的比特数。比特/秒也可以用BPS表示,kBPS表示千比特/秒。
Binding
The process of making the logical connections to the network (also called connecting). This involves connecting network variable outputs to network variable inputs using LonWorks software.
yhm321 | 2012-12-15 19:30:02 | 显示全部楼层
缥缈之旅 | 2011-10-9 07:00:12 | 显示全部楼层
努力,努力,再努力!!!!!!!!!!!
subi | 2011-10-9 07:00:12 | 显示全部楼层
ding   支持
找不到我 | 2011-10-9 07:00:12 | 显示全部楼层
写得好啊 估计有马甲
