轴承产品专业术语中英文翻译对照
查看2457 | 回复0 | 2011-9-14 19:52:01 | 显示全部楼层 |阅读模式
adapter bearing带固接套的轴承
adjustable bearing可调轴承
adjustable cone colter bearing圆犁刀的可调式锥形轴承
aerostatic bearing空气静力轴承
agate bearing玛瑙轴承
air journal bearing气体轴承
air lubricated thrust bearing空气润滑止推轴承
aligning bearing(直线)对位轴承
alkaline-friction bearing抗磨轴承
allowable bearing容许支承力
all-rubber type bearing全胶式轴承。全橡胶轴承
aluminum base bearing铝基合金轴承
aluminum-tin bearing铝锡合金轴承
angular ball bearing径向止推滚珠轴承
angular contact ball bearing角面接触滚珠轴承,向心止推滚珠轴承
angular contact journal bearing角面接触轴颈轴承
annular ball bearing向心球轴承,径向滚珠轴承
annular contact thrust ball bearing推力向心球轴承
antenna bearing(电磁)天线方位
antifriction thrust bearing减磨推力轴承,减磨止推轴承
antithrust bearing止推轴承
asymmetrical roller bearing非对称滚子轴承
axial bearing支撑轴承,止推轴承
axial thrust bearing轴向推力轴承
axle box bearing轴箱轴承
azimuth bearing方位
babbit metal (cast) bearing(铸造)巴氏合金轴承
babbit-lined bearing巴氏合金衬套轴承,衬巴氏合金的轴承
back bearing反象限角,后轴承,反方位(炮)
back-to-back duplex bearing成对双联轴承(外圈宽端面相对)
ball bearing滚珠轴承
ball collar thrust bearing滚珠环止推轴承,滚珠环推力轴承
ball journal bearing球颈轴承
ball thrust bearing止推滚珠轴承
barrel bearing圆筒轴承
base bearing主轴承,底轴承,基轴承
bellbearing钟杆推力轴承,小钟杆平球架,炉钟杠杆
bevel pinion front bearing小锥齿轮前[后]轴承
big-end bearing大端轴承
blade bearing刃型支承
block bearing支承轴承,止推轴承
boring bar bearing镗杆轴承
box bearing空转轴承
bracket bearing托架轴承
bushing bearing衬套轴承
cageless rolling bearing无保持架轴承
camshaft bearing凸轮轴轴承
center bearing下心盘,下心盘支承面;中心支承
centring spring rod bearing调准簧杆轴承
ceramic bearing陶瓷轴承
check bearing检验方位,检验轴承
circular unidirectional thrust bearing环状单向推力轴承
closed-type bearing密闭形轴承
clutch release bearing离合器分离轴承
collar (thrust) bearing环形止推轴承
combination bearing组合轴承
commutator side bearing整流子侧支座
composite bearing多层轴瓦,复合轴承
compressed air bearing压缩空气轴承,压气轴承
concentric adjustable bearing同心调整轴承
conical bearing圆锥轴承
corrugated bearing梳状轴承,槽形轴承
countershaft gear bearing副轴齿轮轴承
crank(ed) bearing曲轴轴承,曲柄轴承,连杆轴承
cross head holt bearing十字头销轴承
cross head pin bearing十字头销轴承
cryogenic bearing低温轴承
cup-and-cone bearing对开径向上止推轴承
cutter bearing滚刀轴承
declutch shaft bearing离合器操纵轴承,分离轴轴承
diamond bearing金刚石轴承
die cast bearing模铸轴承
differential drive pinion cage bearing差速器主小齿轮轴承罩
differential side bearing差速器壳轴承
disk bearing圆盘轴承
disk harrow bearing圆盘耙轴承
distributor upper bearing配电器上轴承
double bearing双列轴承
double shield bearing双(护)罩轴承
double thrust bearing双止推轴承
double-row angular contact ball bearing双列向心推力球轴承
double-row ball journal bearing双列径向滚珠轴承
double-row radial ball bearing双列向心球轴承
double-row radial spherical roller bearing双列向心鼓面滚子轴承
double-row self-aligning spherical roller bearing双列向心球面滚子轴承(自动调心型)
drag link bearing拉杆支座
drive end bearing主动端轴承,驱动端轴承
drive pinion cone bearing主动小齿轮锥形轴承
drive shaft bearing主动轴轴承
drop-hanger bearing悬挂轴承
drum roller bearing鼓形滚柱轴承
dry bearing干轴承
duplex bearing双轴承
duplex ball bearing成对双联向心推力球轴承
dynamo bearing发电机轴承
elastically yielding bearing弹性退让轴承
elliptical bearing椭圆形轴承
enclosed tubular bearing密封套管轴承(属于油浴润滑式轴承)
end journal bearing端枢轴承
end shield bearing机油滤清器内盖头轴承
end thrust bearing止推轴承
end-mounted bearing(耙组)两端安装的轴承
engine thrust ball bearing止推滚珠轴承
established line bearing非标准轴承
expansion bearing活动支承,温度)伸胀支承
expansive end bearing of bridge活动桥支座
fabric bearing夹布胶木轴承
fan end thrust ball bearing风扇端止推滚球轴承
fan shaft bearing风扇轴轴承
Ferro porit bearing渗硫铁系含油轴承
filling slot type bearing填槽式轴承
film bearing油膜轴承
film lubrication bearing油膜轴承,液体摩擦轴承
