PIC单片机的I2C读写源程序
查看1397 | 回复0 | 2011-9-7 22:59:24 | 显示全部楼层 |阅读模式
TITLE \" TWO WIRE/I2C BUS INTERFACE WITH PIC16C5x \"
LIST P=16C54
;** Two wire/I2C Bus READ/WRITE Sample Routines of Microchip's
;** 24Cxx / 85Cxx serial CMOS EEPROM interfacing to a
;** PIC16C54 8-bit CMOS single chip microcomputer
;** Revsied Version 2.0 (4/2/92).
;** Part use = PIC16C54-XT/JW
;** Note: 1) All timings are based on a reference crystal frequency of 2MHz
;** which is equivalent to an instruction cycle time of 2 usec.
;** 2) Address and literal values are read in octal unless otherwise
;** specified.
; Program: I2CBUS.ASM
; Revision Date:
; 12-12-95 Compatibility with MPASMWIN 1.30
; Files Assignment
PC EQU 2 ; Program counter
STAT EQU 3 ; PIC status byte
FSR EQU 4 ; File Select Register
RA EQU 5 ; Port A use to select device address
RB EQU 6 ; RB7 = SDA, RB6 = SCL
STATUS EQU 08 ; Status register
FLAG EQU 09 ; Common flag bits register
EEPROM EQU 0A ; Bit buffer
ERCODE EQU 0B ; Error code (to indicate bus status)
ADDR EQU 10 ; Address register
本新闻共9页,当前在第1页 [1] [2] [3] [4] [5] [6] [7] [8] [9]
