印制电路词汇
印制电路词汇
2011-9-7 22:35:22
一、综合词汇
1、印制电路:printedcircuit
2、印制线路:printedwiring
3、印制板:printedboard
4、印制板电路:printedcircuitboard(PCB)
5、印制线路板:printedwiringboard(PWB)
6、印制元件:printedcomponent
7、印制接点:printedcontact
8、印制板装配:printedboardassembly
9、板:board
10、单面印制板:single-sidedprintedboard(SSB)
11、双面印制板:double-sidedprintedboard(DSB)
12、多层印制板:mulitlayerprintedboard(MLB)
13、多层印制电路板:mulitlayerprintedcircuitboard
14、多层印制线路板:mulitlayerpritedwiringboard
15、刚性印制板:rigidprintedboard
16、刚性单面印制板:rigidsingle-sidedprintedborad
17、刚性双面印制板:rigiddouble-sidedprintedborad
18、刚性多层印制板:rigidmultilayerprintedboard
19、挠性多层印制板:flexiblemultilayerprintedboard
20、挠性印制板:flexibleprintedboard
21、挠性单面印制板:flexiblesingle-sidedprintedboard
22、挠性双面印制板:flexibledouble-sidedprintedboard
23、挠性印制电路:flexibleprintedcircuit(FPC)
24、挠性印制线路:flexibleprintedwiring
25、刚性印制板:flex-rigidprintedboard,rigid-flexprintedboard
26、刚性双面印制板:flex-rigiddouble-sidedprintedboard,rigid-flexdouble-sidedprinted
27、刚性多层印制板:flex-rigidmultilayerprintedboard,rigid-flexmultilayerprintedboard
28、齐平印制板:flushprintedboard
29、金属芯印制板:metalcoreprintedboard
30、金属基印制板:metalbaseprintedboard
31、多重布线印制板:mulit-wiringprintedboard
32、陶瓷印制板:ceramicsubstrateprintedboard
33、导电胶印制板:electroconductivepasteprintedboard
34、模塑电路板:moldedcircuitboard
35、模压印制板:stampedprintedwiringboard
36、顺序层压多层印制板:sequentially-laminatedmulitlayer
37、散线印制板:discretewiringboard
38、微线印制板:microwireboard
39、积层印制板:buile-upprintedboard
40、积层多层印制板:build-upmulitlayerprintedboard(BUM)
41、积层挠印制板:build-upflexibleprintedboard
42、表面层合电路板:surfacelaminarcircuit(SLC)
43、埋入凸块连印制板:B2itprintedboard
44、多层膜基板:multi-layeredfilmsubstrate(MFS)
45、层间全内导通多层印制板:ALIVHmultilayerprintedboard
46、载芯片板:chiponboard(COB)
47、埋电阻板:buriedresistanceboard
48、母板:motherboard
49、子板:daughterboard
50、背板:backplane
51、裸板:bareboard
52、键盘板夹心板:copper-invar-copperboard
53、动态挠性板:dynamicflexboard
54、静态挠性板:staticflexboard
55、可断拼板:break-awayplanel
56、电缆:cable
57、挠性扁平电缆:flexibleflatcable(FFC)
58、薄膜开关:membraneswitch
59、混合电路:hybridcircuit
60、厚膜:thickfilm
61、厚膜电路:thickfilmcircuit
62、薄膜:thinfilm
63、薄膜混合电路:thinfilmhybridcircuit
64、互连:interconnection
65、导线:conductortraceline
66、齐平导线:flushconductor
67、传输线:transmissionline
68、跨交:crossover
69、板边插头:edge-boardcontact
70、增强板:stiffener
71、基底:substrate
72、基板面:realestate
73、导线面:conductorside
74、元件面:componentside
75、焊接面:solderside
76、印制:printing
77、网格:grid
78、图形:pattern
79、导电图形:conductivepattern
80、非导电图形:non-conductivepattern
81、字符:legend
82、标志:mark
二、基材:
1、基材:basematerial
2、层压板:laminate
3、覆金属箔基材:metal-cladbadematerial
4、覆铜箔层压板:copper-cladlaminate(CCL)
5、单面覆铜箔层压板:single-sidedcopper-cladlaminate
电工工作人员的基本要求
触电急救培训工作中存在的问题及对策
当前农电安全管理存在的问题与对策
双绞线
电力电缆和控制电缆的区别
防止电力生产重大事故的二十五项重点要求继电保护实施细则
二台电机顺序起动加时间延时电路
电力系统继电保护技术监督规定(试行)
单相电机顺逆转
单相电机逆顺接法
智能数控系统技术进展
电表接线图
永不消逝的电波
定时、中断练习
常用场效应管参数表
常用光电耦合器
可调稳压电路
快速识别色环电阻阻值
《电工电子技术基础》电子书免费下载
矿山电子修理工技能鉴定理论题库
2014-2-22 20:00:26
alishan
2011-9-7 22:35:35
6、双面覆铜箔层压板:double-sidedcopper-cladlaminate
7、复合层压板:compositelaminate
8、薄层压板:thinlaminate
9、金属芯覆铜箔层压板:metalcorecopper-cladlaminate
10、金属基覆铜层压板:metalbasecopper-cladlaminate
11、挠性覆铜箔绝缘薄膜:flexiblecopper-claddielectricfilm
12、基体材料:basismaterial
13、预浸材料:prepreg
14、粘结片:bondingsheet
15、预浸粘结片:preimpregnatedbondingsheer
16、环氧玻璃基板:epoxyglasssubstrate
17、加成法用层压板:laminateforadditiveprocess
18、预制内层覆箔板:masslaminationpanel
19、内层芯板:corematerial
20、催化板材:catalyzedboard,coatedcatalyzedlaminate
21、涂胶催化层压板:adhesive-coatedcatalyzedlaminate
22、涂胶无催层压板:adhesive-coateduncatalyzedlaminate
23、粘结层:bondinglayer
24、粘结膜:filmadhesive
25、涂胶粘剂绝缘薄膜:adhesivecoateddielectricfilm
26、无支撑胶粘剂膜:unsupportedadhesivefilm
27、覆盖层:coverlayer(coverlay)
28、增强板材:stiffenermaterial
29、铜箔面:copper-cladsurface
30、去铜箔面:foilremovalsurface
本新闻共3页,当前在第1页 [1] [
huangshan
