S100型掘进机电器部分常见故障分析
查看2977 | 回复4 | 2014-10-17 20:12:43 | 显示全部楼层 |阅读模式
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image001.gif
按信号按钮 电铃不响
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image002.gif
按住信号按钮观察PLC输出端1000是否亮
警按钮
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image003.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image004.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image005.gif
如不亮
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image006.gif
检查按钮SB5及连线是否正常
                                        吸合
测量电铃电源19和T5是否有120V
        不
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image007.gif有                 合
检查电铃是否损坏,如损坏更换
说明KA6有故障,更换
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image008.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image009.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image010.gif
截割电机及二运电机不启动的故障排除方法和油泵电机的基本相同
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image011.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image012.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image013.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image014.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image015.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image016.gif
S150JA型掘进机电气部分故障分析
油泵过温
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image017.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image018.gif
检查油泵回路电机和电缆绝缘
660V/1140V漏电电阻22KΩ/40KΩ
电机正常,测量热敏电阻
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image019.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image020.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image021.gif截割电机,二运电机漏电 过温 过载 断相等故障的排除参照上述方法
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image022.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image023.gif
S512-009系列综合保护器常见故障
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image024.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image025.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image026.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image027.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image028.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image029.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image030.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image031.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image032.gif
file:///C:/Users/lenovo/AppData/Local/Temp/msohtml1/01/clip_image033.gif
我爱梅西 | 2015-2-10 22:15:56 | 显示全部楼层
lkccwyp@163.com | 2015-2-10 00:28:57 | 显示全部楼层
什么弹道导弹核潜艇
123飞翔 | 2014-10-18 19:55:04 | 显示全部楼层
心海 发表于 2014-10-18 12:49
什么东东啊 !  看不了。
不好意识,可能图片没发上去
心海 | 2014-10-18 12:49:15 | 显示全部楼层
什么东东啊 !  看不了。:@
