常用晶体管
查看1637 | 回复0 | 2011-12-5 00:26:36 | 显示全部楼层 |阅读模式
型号(规格)M/Pol电压VCEO(V)电流 IC(A)功率 PC(W)兼容型号
TIP122SI-NPN100565BD266,BD646,BD698
TIP127SI-PNP100565BD266B,BD650,BD702
TIP41BSI-NPN80665BD243B
TIP41CSI-NPN100665BD243C
TIP42CSI-PNP100665BD244C
BU406SI-NPN4007603DK308A,D2373
BU508ASI-NPN15007.575
2N3055SI-NPN10015117BD130,BDX10,3DD71D
MJE13003SI-NPN4001.520KSE13003
MJE13005SI-NPN400475KSE13005,
MJE13007SI-NPN400880KSE13007
MJE13009SI-NPN40012100KSE13009
2SB772SI-PNP40310BD786,3CA5A
2SD882SI-NPN40310BD785,3DA92A
2SB562SI-PNP2510.9BC328,BC298,BC728
2SA1013SI-PNP16010.9KSA1013,BF491
2SA940SI-PNP1501.525KSA940,2N6476,3CA10F
2SB647SI-PNP12010.9BF491,3CA3F
2SD667SI-NPN12010.9BF391,3DK104E
2SC1213SI-NPN350.50.4BC337,3DK4A
2SC5609SI-NPN
2SD965SI-NPN4050.75
2SA1015GRSI-PNP500.150.4HA1015,BC177,CG673
9011SI-NPN3030mA400mW
9012SI-PNP200.5625mW
9013SI-NPN200.5625mW
9014SI-NPN450.1450mW
9015SI-PNP450.1450mW
9016SI-NPN2025mA400mW
9018SI-NPN1550mA400mA
8050SI-NPN251.51
8550SI-PNP251.51
2N5551SI-NPN1600.6625mW
2N5401SI-PNP1600.6625mW
2SC1815SI-NPN600.150.4BC184,BC384,DG1815
2SC1959SI-NPN350.50.5BC338,BC378,3DA2060,3DG1959
2SA928SI-PNP KSA928
2SC945SI-NPN500.1250MHzKSC945
2N3904SI-PNP600.2 MMBT3904,2N2220,3DK40B
2N3905SI-PNP400.2 MMBT3905,2N2906,3CK3F
2N3906SI-PNP400.2 MMBT3906,2N2906,3CK3F
A42SI-NPN350.50.4
A92SI-NPN MMBTA92
2SC1623L6SI-NPN500.1300MHz
2SC3356R25SI-NPN200.10.2fr=7GHz
